8206.01 Release Notes
Monday, July 8, 2019 | wf062819a Gen 38 | 8206 Gen 1738 |
as062819a |
New autoGlobal Property to Synchronize Maximum and Minimum Values on Dual-Y and Split-Y Charts
You can synchronize the minimum and maximum values on dual-y and split-y charts using the "autoGlobal" property for the axis minimum and maximum values. If both the minimum and maximum values are synchronized for multiple y-axes, their scales will also be synchronized.
Synchronize the Axis Maximum and Minimum Values on Dual-Y and Split-Y Charts
"yaxis": { "min": "autoGlobal", "max": "autoGlobal" }, "y2axis": { "min": "autoGlobal", "max": "autoGlobal" }
or
"axisList": { "y1": { "min": "autoGlobal", "max": "autoGlobal" }, "y2": { "min": "autoGlobal", "max": "autoGlobal" }, ... }
Example: Synchronizing Scales on a Dual-Y Chart
The following request generates a line chart with dual-y axes, without synchronizing their minimum and maximum values.
GRAPH FILE WF_RETAIL_LITE SUM COGS_US DISCOUNT_US BY PRODUCT_CATEGORY ON GRAPH PCHOLD FORMAT JSCHART ON GRAPH SET LOOKGRAPH LINE ON GRAPH SET STYLE * type=data, column=n1, bucket=x-axis,$ type=data, column=n2, bucket=y-axis,$ type=data, column=n3, bucket=y-axis(2),$ ENDSTYLE END
The output is shown in the following image.
The following version of the request synchronizes the maximum values for both y-axes. Since the minimum values are equal without the autoGlobal property, it is not necessary to implement that property for this chart.
GRAPH FILE WF_RETAIL_LITE SUM COGS_US DISCOUNT_US BY PRODUCT_CATEGORY ON GRAPH PCHOLD FORMAT JSCHART ON GRAPH SET LOOKGRAPH LINE ON GRAPH SET STYLE * type=data, column=n1, bucket=x-axis,$ type=data, column=n2, bucket=y-axis,$ type=data, column=n3, bucket=y-axis(2),$ *GRAPH_JS "axisList": { "y1": { "max": "autoGlobal" }, "y2": { "max": "autoGlobal" } } *END ENDSTYLE END
For more information, see the Creating HTML5 Charts With WebFOCUS Language manual.
New SET Commands to Automatically Fit Multiple Charts in a Container
SET AUTOFIT command controls whether HTML5 chart output resizes to fit into the container in which it is placed. Two new SET commands implement AUTOFIT for a request that generates multiple charts. In order for these commands to take effect, AUTOFIT must also be enabled:
- SET AUTOFIT-MULTI specifies whether to automatically fit multiple charts in the container.
- SET AUTOFIT-MIN-PCT defines a minimum height for each chart.
Syntax: How to Automatically Fit Multiple Charts in a Container
ON GRAPH SET AUTOFIT-MULTI {ON|OFF} ON GRAPH SET AUTOFIT-MIN-PCT pct
where:
ON
Enables automatic fitting of multiple charts in their container. AUTOFIT must also be set to ON or RESIZE.
OFF
Disables automatic fitting of multiple charts.
pct
Is the minimum height of each chart, as a percentage of the VAXIS value. The default AUTOFIT-MIN-PCT value is 100. If the charts do not all fit
vertically in the container with that minimum height, the window will be generated with a scroll bar.
Example: Automatically Fitting Multiple Charts in Their Container
The following request generates a chart for each value of the BUSINESS_REGION field. AUTOFIT is set ON, AUTOFIT-MULTI is set ON, and AUTOFIT-MIN-PCT is set to 50% of the VAXIS value.
GRAPH FILE WF_RETAIL_LITE HEADING CENTER "Region: <BUSINESS_REGION" SUM COGS_US REVENUE_US BY BUSINESS_REGION NOPRINT BY PRODUCT_CATEGORY ON GRAPH PCHOLD FORMAT JSCHART ON GRAPH SET LOOKGRAPH LINE ON GRAPH SET EMBEDHEADING ON ON GRAPH SET VAXIS 200 ON GRAPH SET AUTOFIT ON ON GRAPH SET AUTOFIT-MULTI ON ON GRAPH SET AUTOFIT-MIN-PCT 50 ON GRAPH SET STYLE * type=heading, size=16, style=bold, $ TYPE=DATA, COLUMN=N1, BUCKET=page, $ TYPE=DATA, COLUMN=N2, BUCKET=x-axis, $ TYPE=DATA, COLUMN=N3, BUCKET=y-axis, $ TYPE=DATA, COLUMN=N4, BUCKET=y-axis, $ END
The output is shown in the following image. All four charts fit in the window, and no scrollbar is generated.
Enhanced FTP Server Configuration Management
ReportCaster administrators who wish to take advantage of the speed and efficiency of the FTP protocol for scheduled report distributions can now create and manage predefined FTP Server connection configurations from the Configuration tab in the ReportCaster console, as shown in the following image.
Predefined FTP Setting configurations can be made available to FTP distribution schedules as shown in the following image.
This new feature is an enhancement of the existing capability to create FTP setting configurations within individual schedules. However, administrators can deactivate this capability and limit all schedules to predefined FTP settings by selecting the Don’t allow user defined FTP in schedule check box in the (Default Settings) configuration
This ability to limit users to predefined FTP Setting configurations enables administrators to manage all FTP Setting configurations from a central location, and ensures that users always select a valid FTP Server connection when creating FTP or File system distribution schedules.
To learn more, see Using the FTP Distribution Option.
- When using a dual-axis graph, linear trendlines used for measures on the Y2-axis are displayed using the scale of the Y1-axis. (190304015)
- Added validation for variable name of IBIF_focexec for valid focexec names. (190212043)
- The enhanced In-Document Analytics user interface available is configured by default for new installations and is not supported with the Microsoft Internet Explorer 11 browser. If you have requirements to support Microsoft Internet Explorer 11 browser, you can configure the Legacy In-Document Analytics user interface using the WebFOCUS Administration Console.
- When creating interactive Dashboards, you can only use Fullscreen mode to modify chart or report (grid) components. Other Dashboard components, such as images and text, do not display.
- When working in Document mode with In-Document Analytics, an error occurs if you attempt to run a document or dashboard using Internet Explorer 11.
- Changing the chart type at run-time is not supported for an AHTML chart that has ARVERSION=1 and which does not use the new chart properties (bucket syntax). As a workaround, convert the chart to use the new chart attributes (recommended), or set ARVERSION to 1.
- When creating reports in WebFOCUS Designer using the Technical Preview feature, the default font may not display all NLS characters correctly. To ensure that these characters display properly in reports, change the values of the FONT attributes, in the report section of the embedded StyleSheet you are using, to a font that supports the required NLS characters. For example:
This release is now certified and has been tested with Google Chrome version 75 and Firefox version 67.
