8206.02 Release Notes
Friday, July 19, 2019 | wf071519a Gen 44 | 8206 Gen 1740 |
as071519a |
There were no new features introduced in this release.
- When you have multiple multi-drill reports laid out side-by-side on an HTMLFORM, if you drill on a report from the right side, the reports on the left disappear. (190701056)
- An HTML report that results in a single row of data, and which has HFREEZE=ON with Subtotals, displays only the subtotals at run time. (190422019)
- JavaScript and Cascading Style Sheet files are not being found in the Web Applications area in App Studio. (190612037, 190703004)
- Display value not working properly for date field in App Studio. (190425084, 190613053)
- A calendar widget in App Studio is not selecting the current hour and minutes in the calendar. (190602007)
- Maintain Data migration support added for applications that reside in multiple folders. (190627085)
- If you limit FTP Setting configurations to a predefined list by selecting the Don’t allow user defined FTP in schedule check box in the (Default Settings) configuration, the previous FTP Setting configuration information for all schedules becomes unavailable, and is replaced by the default FTP Setting configuration or a predefined FTP Setting configuration selected for an individual schedule.
- After an upgrade to Release 8206, only those users working in roles that include the new Create Shortcuts (opShortcut) privilege, located in the Basic Reporting privilege category, can continue to create shortcuts. Even though this privilege is included in the DomainBasicUser, DomainAdvancedUser, DomainDeveloper, DomainAnalyst, and WebFOCUSManager roles, it is not selected by default. Administrators must either select the Create Shortcuts privilege check box directly, or use the Role Update utility located on the Configuration tab of the Administration Console, to include this privilege in each of the roles that can continue to use this feature.
- The Display Esri® Configuration Utility (opEsriAdminConsole) privilege, which granted access to the Esri Configuration Utility, was removed from the Application Development privilege category located on the Roles tab of the Security Center. The new ArcGIS API for JavaScript replaces the Esri Configuration Utility and is available to all users. Existing maps created using the Esri Configuration Utility continue to work with the new ArcGIS API for JavaScript. However, you cannot upgrade them without first recreating them with the new Esri HTML5 component-based Point Map or Choropleth Map options available from the WebFOCUS Designer or InfoAssist Chart Picker.
- The enhanced In-Document Analytics user interface available is configured by default for new installations and is not supported with the Microsoft Internet Explorer 11 browser. If you have requirements to support Microsoft® Internet Explorer® 11 browser, you can configure the Legacy In-Document Analytics user interface using the WebFOCUS Administration Console.
To convert content created in earlier versions to the WebFOCUS Designer display, developers must open that content for editing, reset the value in the In-Document Analytics setting to WebFOCUS Designer, and save the revised procedure. As an alternative, developers can use the text editor to add the following commands directly to a procedure.
- In order to prevent unexpected field transformations when creating a chart in WebFOCUS Designer, the buckets are type sensitive. Certain buckets, such as the Size and Tooltip buckets, only accept measure fields, while others, such as the Horizontal and MultiPage buckets, only accept dimension fields. Additional buckets, such as the Vertical and Color buckets, accept both field types. When you attempt to drag a field into an incompatible bucket, the cursor changes to a cancel sign.
To add a measure field to a dimension bucket or a dimension field to a measure bucket, right-click a field in the Fields panel and click Add as dimension or Add as measure. The field is added to the default dimension or measure bucket. You can drag the field into another bucket, as needed. As in previous releases, measure fields used as dimensions display as distinct instead of aggregated values, while dimension fields used as measures are aggregated using the Count operation.
- When creating interactive Dashboards, you can only use Fullscreen mode to modify chart or report (grid) components. Other Dashboard components, such as images and text, do not display.
- If you are working with an In-Document Analytics chart in landscape mode on an Android® mobile device and you switch to portrait mode, your content displays in fullscreen mode. Your chart displays at the bottom. If you run your content in new window mode, your In-Document Analytics chart does not display in fullscreen mode, displaying the chart on the right.
- When working in Document mode with In-Document Analytics, an error occurs if you attempt to run a document or dashboard using Internet Explorer 11.
- When creating bar charts using the New option on the ellipsis menu, the Color bucket incorrectly performs a count for a dimension field. It also shows a heat legend. The expected result is a color legend for each unique item.
- When you use the WebFOCUS Online Help in Japanese, if you type a search term in the Search box that contains NLS characters and press the Enter key, the words next to the Search box are corrupted. The workaround is to click the Go button next to the Search box, instead of pressing the Enter key.
- When creating reports in WebFOCUS Designer using the Technical Preview feature, the default font may not display all NLS characters correctly. To ensure that these characters display properly in reports, change the values of the FONT attributes, in the report section of the embedded StyleSheet you are using, to a font that supports the required NLS characters. For example:
There were no system requirement changes introduced in this release.
