8206.03 Release Notes
Friday, August 2, 2019 | wf072519a Gen 52 | 8206 Gen 1741 |
as072519a |
Options to Include the Selected Value When Specifying Minimum and Maximum Filter Values
Additional filtering options are now available for numeric fields and date fields in WebFOCUS Designer charts and reports. These options enable you to include the selected value when you specify the minimum and maximum filter values in a control. You can use the Greater than or equal and Less than or equal options for numeric field filters, and the On or after and On or before options for date field filters. In the following image, a minimum filter value is set to 100,000,000, using the Greater than or equal option.
For more information, see Adding Filters to Content.
Ability to Select Fields for Previewing and Creating Filters in a Profile Bar Chart
From the Web Console, when viewing profile bar charts in a data flow, you can now select one or more values to see how your selection affects the other fields in your data. This allows you to preview your data filters, before you create them. If the preview provides the desired extract of your data, you can then use your selection to create a permanent filter that includes or excludes the selected fields when your data is loaded to a target.
For more information, see Filtering Data in Profile Bar Charts.
SET Command for Synchronizing WebFOCUS Page Breaks With Excel Page Breaks
You can use the SET XLSXPAGEBRKIGNORE command to control whether page breaks in WebFOCUS format XLSX report output insert Excel page breaks at the same points in the output. You can use this setting to apply default Excel page breaks instead of the page breaks from the report. By default, the page breaks will be synchronized.
For more information, see Creating Reports With WebFOCUS Language.
Attribute for Scaling PDF Report Output to Fit the Page Width
By default, if PDF report output is too wide to fit on a single page, the report generates multiple panels of the same page for the columns that do not fit. The page numbers specify the page and panel numbers. For example, page numbers 1.1 and 1.2 represent page 1/panel 1 and page 1/panel 2. You can scale the output to fit across the width of the page using the PAGE-SCALE StyleSheet attribute or the PAGE-SCALE SET parameter.
Technical Preview: New Repository Search and Navigation Widgets for Embedding in Portals
You can now embed the new Home and Navigation Widgets in your portal or pages to create an app-like display, and provide users with new search functionality and repository navigation options. These URL-based widgets are available as Technical Preview features in Release 8206.03, and include the ability to access recent items, favorites, and portals in a single view.
For more information, see Embedding Search and Navigation Widgets in Portals.
Using URL Images as Markers in an HTML5 Chart
Using the chart template engine, if you have a field in your data that contains URL references that point to per-series or per-group images, you can display those images as markers on an HTML5 chart.
For more information, see Creating HTML5 Charts With WebFOCUS Language.
- Date validation does not work for calendar controls. (190417081)
- The push button style check box controls are not aligning the text properly. (190617005, 190626069)
- Some FocIndex variables do not migrate to App Studio Maintain Data. (190701054)
- A Maintain Data onOpen trigger does not migrate to the new App Studio Maintain Data paradigm. (190703053)
- When loading layers asynchronously, the onAfterLoad event is called before all of the layers are loaded. (190701083)
- When NLS is configured for Unicode - 65001, and the field name containing Database Management System characters are added to the Color BY bucket of a visualization or AHTML chart, a Request failed. Your session may have expired error occurs. (190408125)
- The border is not displayed correctly when using a combination of an ACROSS statement in a multi-verb request, with SET BYPANEL = ON and SET ACROSSTITLE = ABOVE. (180724018)
- When using SET BYDISPLAY = ACROSS with a field containing missing data and multiple SUM fields for PDF, HTML, and DHTML formats, some values are displayed with the missing character placeholder rather than their values. (190318001)
- Using the Data Management Console and editing a flow or synonym with an expression comparing a field calculated as a date part and comparing it with a number results in a FOC177 INVALID DATE CONSTANT error message.
- When creating a new calculation in Content Designer using Internet Explorer version 11 browser, Japanese text cannot be typed in as the computation name using Input Method Editors. (190313005)
- The enhanced In-Document Analytics user interface available is configured by default for new installations and is not supported with the Microsoft Internet Explorer 11 browser. If you have requirements to support Microsoft Internet Explorer 11 browser, you can configure the Legacy In-Document Analytics user interface using the WebFOCUS Administration Console.
- When working in Document mode with In-Document Analytics, an error occurs if you attempt to run a document or dashboard using Internet Explorer 11.
- When creating reports in WebFOCUS Designer using the Technical Preview feature, the default font may not display all NLS characters correctly. To ensure that these characters display properly in reports, change the values of the FONT attributes, in the report section of the embedded StyleSheet you are using, to a font that supports the required NLS characters. For example:
This release is now certified and has been tested with Google Chrome version 75, Firefox version 68, Internet Explorer version 11, and Microsoft Edge version 44 (WebFOCUS only).
