8206.05 Release Notes
Friday, August 30, 2019 | wf082319a Gen 71 | 8206 Gen 1743 |
as082319a |
New WebFOCUS Integrated Installation for Linux
WebFOCUS Integrated Installation is a new, simplified installation, which installs and configures all required product components to allow you to use the product for your reporting and analytics needs.
WebFOCUS Integrated Installation is an all-in-one downloadable installation package. Benefits include:
- WebFOCUS and the Reporting Server bundled with Tomcat, Derby, and Java.
- Hyperstage preconfigured as a high-speed target for uploaded data.
- Simplified configuration for email distribution.
With WebFOCUS Integrated Installation, you can quickly and easily perform reporting and analysis, data discovery, and scheduling and distribution, all in a single web-based environment.
For more information, see WebFOCUS Integrated Installation.
Enhancements to the Refresh BI Portal Drill-Down Option
When creating charts and reports in InfoAssist and App Studio, you can create drilldowns using the Refresh BI Portal option. When that content is run as part of a page in a portal, selecting a drill-down link passes the selected value to any parameters that use the specified parameter name in content on the page or in the entire portal. This allows you to synchronize all of the content in a portal, and even use drilldowns in your content as a replacement for filter controls. Portal refresh behavior has been enhanced and is available in collaborative portals as well as Designer portals.
For more information, see the Using Drilldowns to Refresh and Filter Items in a Portal topic, or the How to Use Drill-Down Links to Filter a Portal video.
- An invalid date constant error occurs when working with a chart with a date in a drilldown. (190306007)
- Multiline dataLabels objects in an HTML5 Pie chart should not overlap. (180315023)
- When a page created in WebFOCUS Designer is run from the Home Page, all controls disappear. (190802101)
- In an App Studio HTML page, the colors for selected and deselected push button style radio buttons do not work. (190802122)
- Filter values that are changed when returning to the Responsive Autoprompt filter panel after an initial successful run are not applied when running the procedure again. (190723039, 190725125, 190819062)
- When using Oracle for the Repository and a Distribution List for a schedule, a run-time exception will occur. (190725027, 190815051)
- An issue occurs when running a PDF report with LAYOUTRTL=OFF and LANG=ARABIC and the data contains Arabic characters. (180914027)
- The enhanced In-Document Analytics user interface available is configured by default for new installations and is not supported with the Microsoft Internet Explorer 11 browser. If you have requirements to support Microsoft Internet Explorer 11 browser, you can configure the Legacy In-Document Analytics user interface using the WebFOCUS Administration Console.
- When clicking a column for a report that has only the Freeze option enabled, and the width of the report container is big enough to display all columns, a blank column menu displays.
- When working in Document mode with In-Document Analytics, an error occurs if you attempt to run a document or dashboard using Internet Explorer 11.
- When creating reports in WebFOCUS Designer using the Technical Preview feature, the default font may not display all NLS characters correctly. To ensure that these characters display properly in reports, change the values of the FONT attributes, in the report section of the embedded StyleSheet you are using, to a font that supports the required NLS characters. For example:
- When using the Chrome 76 browser, the show filter panel icon on the responsive autoprompt interface does not redisplay the filter panel after the first run of a report with parameters. This behavior does not occur with the Chrome 77, Firefox, or IE11 browsers.
This release is now certified and has been tested with Google Chrome version 76, Firefox version 68, Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11.
