8206.06 Release Notes
Friday, September 13, 2019 | wf090619a Gen 79 | 8206 Gen 1744 |
as090619a |
Merging WebFOCUS Content With PowerPoint Template Content
Using the TEMPLATE-ACTION Stylesheet attribute, you can merge WebFOCUS content with PowerPoint template content. The MERGE action allows you to edit components, such as comments in native PowerPoint text boxes, in the resulting PowerPoint PPTX output.
To merge WebFOCUS content with PowerPoint template content, include the following StyleSheet syntax in your procedure.
TYPE=REPORT, TEMPLATE-ACTION=MERGE ,$
Note: You can include the TEMPLATE-ACTION=REPLACE StyleSheet attribute to retain the default behavior, which causes WebFOCUS output to override all target slide content.
The following image shows WebFOCUS content merged with PowerPoint template content.
For more information, see the Creating Reports With WebFOCUS Language manual.
Adapter for Apache Hive: Mapping CLOB Columns as STRING Format
In prior releases, when creating a synonym for a Hive table, a CLOB column was described in the synonym with format TX. CLOB columns are now described with USAGE=STRING, ACTUAL=STRING.
Technical Preview: New Copy and Update Paths Menu Option Updates IBFS Paths Automatically
The new Copy and Update Paths menu option is available as a technical preview feature in Release 8206.06. This new menu option transfers copies of charts, reports, documents, visualizations, pages, workbooks, schedules, and HTML files created in App Studio from one folder to another within the same level of the IBFS hierarchy.
When you open the shortcut menu after selecting one or more of these items within a single folder, you can select this new menu option to transfer copies of the selected items to another folder, as shown in the following image.
When you paste copies of these items to a new folder, the parent folder paths of the IBFS links within the copies are replaced automatically with parent folder paths that identify the new location. This automatic update saves time and prevents potential inaccuracies by eliminating the need for you to update the parent paths of all IBFS links manually after the copy is created.
Note that when you run a copy of an item that was moved using this option, you may receive a warning alerting you that the copied item was modified outside of InfoAssist. This warning does not affect the behavior of the item at run time. To prevent this warning from reappearing, save the copied item in InfoAssist.
This new menu option is available only to users who are granted the new Copy and Update Paths (opCopySpecial) privilege that appears in the Application Development privilege category of the Roles dialog box that opens from the Roles tab of the Security Center.
For more information, see the Copy and Update Paths topic in the Working with Home Page technical content and the Application Development topic of the Security and Administration technical content.
- When an autofit chart is inside an output widget container, the chart will not automatically resize when the container is resized. (190813079)
- Unable to edit a synonym created in a proxy environment. (190823142)
- HTML file with Save Selection option is displayed correctly under My Content, but incorrectly under the Content tree. (190401003)
- If a drilldown passes several parameters, and one of those parameters has a null value, it is passed as FOC_MISSING, but all subsequent parameters are incorrectly passed as FOC_MISSING, producing incorrect output. (190422003, 190116071, 190521073, 190703091, 190730005)
- When using the DB_LOOKUP double select feature, an erroneous blank bar pops up and remains on the browser, even after clicking the Cancel button.
- The Web Console Create Synonym will not allow manual schema override in the Owner/Schema box.
- When two DBA protected synonyms are dynamically joined, the DBA in the second synonym is not activated when that synonym is a cluster. (190620003)
- The user receives an error when the folder name is EDA: Upload Data yields 503 - Service Unavailable (190730069)
- When a Designer chart is accessed, the URL sent incorrectly includes double slashes. Siteminder security configured to block double slashes will block the URL resulting in the chart not opening. (190815130)
- When clicking a column for a report that has only the Freeze option enabled, and the width of the report container is big enough to display all columns, a blank column menu displays.
- When using the Chrome 76 browser, the show filter panel icon on the responsive autoprompt interface does not redisplay the filter panel after the first run of a report with parameters. This behavior does not occur with the Chrome 77, Firefox, or IE11 browsers.
This release is now certified and has been tested with Google Chrome version 76, Firefox version 68, Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11.
