8206.09 Release Notes
Friday, October 25, 2019 | wf102219a Gen 106 | 8206 Gen 1748 |
as102219a |
Updates to the Sort Capabilities for Columns in a Report
You can now sort the columns in your report using the ascending and descending radio buttons, as shown in the following image.
You can also use the up and down arrows in the column header to sort your columnar data.
- Double-clicking a Master File in the filtered file list selects a Master File in the file list behind the filtered list and opens InfoAssist. (190725036)
- An HTTP 403 error or blank screen displays when attempting to access the Reporting Server Console from the WebFOCUS Administration Console after signing out and signing back into WebFOCUS. (190618027)
- When App Studio is set to Japanese, the border style properties are not reflected in preview or at run time. (190910014)
- The third page in a collaborative portal populated with HTML pages created in App Studio appears as blank. (191007059)
- When the following SET command is active, InfoAssist requests will fail, after a system is selected: ENGINE INT SET MFACT-OUTPUT SQL (190925023)
- The Resource Management archive job reports successful processing although an error has occurred and no data is loaded into the repository. Due to this combination, the input rmldata.log data file is also deleted. (190808063)
- Attempting to page a very wide In-Document Analytics cached document may result in a blank page. (190603013).
- In Dialogue Manager, creating an amper variable using concatenation within a looping IF...THEN...ELSE phrase causes the server to crash after the variable exceeds 200 characters. (190905104)
- When running the Web Console's download function using Internet Explorer 11, Japanese file names are corrupted when they display in dialog boxes or the browser's status line. (190903011)
- Running a .fex that uses DYNAM SUBMIT causes a S0C4/agent crash. (190920058)
- Magnify search is slow when feeds contain errors. (190820042)
- The text value ‘ of ’ is not translated to Portuguese while working with an AHTML chart at
run-time and showing a percentage of a value in the chart tooltip. (190410130) - Prompt on a joined field generates incorrect syntax and a FOC003 error when the field
reference in the procedure is in a form APPNAME/SUBAPP1.../SUBAPP_N/
FILE.SEGMENT.FIELD and the Master File resides in a subfolder such as new_retail/
dimensions/wf_retail_product.mas. (191007063)
- When clicking a column for a report that has only the Freeze option enabled, and the width of the report container is big enough to display all columns, a blank column menu displays.
This release is now certified and has been tested with Google Chrome version 77, Firefox version 69, Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11.
