8206.10 Release Notes
Wednesday, November 13, 2019 | wf110419a Gen 115 | 8206 Gen 1749 |
as110419a |
New Settings Support the Solr Search Engine Configuration
New settings, located on the Search Settings page of the Administration Console Configuration tab, identify the location of the Solr search engine and the credentials required to authenticate InfoSearch calls from the WebFOCUS Client to the Solr search engine.
- Solr URL (IBI_INFOSEARCH_SOLR_URL). Identifies the URL for the Solr Search engine. Calls for indexing and searches are directed to this URL.
- Username for Basic Authentication (IBI_SEARCH_USERNAME). Identifies the user name that authenticates Solr-based indexing and search queries.
- Password for Basic Authentication (IBI_SEARCH_PASSWORD). Identifies the password that authenticates Solr-based indexing and search queries.
- Collection Name (IBI_SEARCH_COLLECTION). Contains the name of the collection that contains your search data and is accessible only with a valid Solr username and password.
The placement of these settings in the administration console makes them readily available for configuration and updates.
For more information, see the Search Settings topic of the Security and Administration technical content.
- The Title property is not updated in the Environments Detail panel. (190919107)
- When required parameter values are not entered on a multipage control, the red borders around those controls display on other pages. (191010015)
- There is a time lag between the user and the editor when typing in the JavaScript editor. (190911081)
- The output will not display when using ON TABLE SET POPUPDESC ON and HFREEZE=TOP (or HFREEZE=ON, etc.) in the same report. (190624115)
- If the first report results in no output in an XLSX compound document, the column titles for the second report are missing in the resulting XLSX workbook. (190802013)
- In an HTML report, TABLE SUBHEAD is duplicated on empty reports using ACROSSTITLE=SIDE. (10513510)
- Corrupt PowerPoint output is generated when a template containing 38 or more slides is used in a PPTX report.
- When outputting to Excel format, if Japanese is selected as the language and the default font is bold, the column width is not set correctly and cuts off some of the data. (190322024)
- Enhanced functionality has been added to the Create Synonym process for the OData
adapter to support creating the SEGTYPE definition for child segments based on the OData
Service Navigation property. A Single Entity definition within the OData Service will translate
to SEGTYPE=U. (190903139) - Library distribution of Excel content has incorrect drilldown URLs. (190409040)
- When clicking a column for a report that has only the Freeze option enabled, and the width of the report container is big enough to display all columns, a blank column menu displays.
This release is now certified and has been tested with Google Chrome version 77, Firefox version 69, Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11.
