8206.13 Release Notes
Thursday, December 26, 2019 | wf121819a Gen 134 | 8206 Gen 1753 |
as121819a |
Java Version 11 Support
This release now supports Java Version 11.
- Running a procedure with an Excel template results in an error: File Level Verification and
repair completed. Parts of this book may have been repaired or destroyed. Removed part:
drawing shape. - When running an HTML report with PRINT and GRANDTOTAL, the font size of the grand total
does not match the rest of the report, even though the font size was not set for the grand
total. (190826009) - If the value of a field in an HTML drilldown report starts with a period, WebFOCUS passes
the value as _FOC_MISSING. (191017017, 191018023) - Running a procedure that has an Excel template results in an error preventing the
population of the macros and buttons in Excel: Excel was able to open the file by repairing
or removing the unreadable content. Removed Part: Drawing shape - Attempts to add a new chart fails with an http503 error in Designer when authentication to
Reporting Server is configured for Kerberos. (190905049) - The items in a list box control in an Excel template overlap after feeding it data from a
WebFOCUS XLSX report. If any items are selected, the date on the first sheet’s Balance
Sheet does not update. (190816039) - When a procedure uses an -HTMLFORM to specify a Cascading Style Sheet for styling, a
JavaScript error occurs. (191108005) - Migration support for all servers upgraded to release 8206 has been added. (191114079,
190716017, 190710048, 190709118, 190627081, 190613076, 191210061) - Deferred status page returns as blank when Kerberos connection to Reporting Server is
configured. (190925013) - When starting InfoAssist the correct group profile is not run when the connection from client
to server is Trusted and the group id passed is a custom header with the value of
&IIBIMR_domain. (190311125, 190620107, 190814009) - The iSeries 8206 Reporting Server downloadable savefiles are missing key files preventing
installation. (191203073) - When setting a SUM field to Japanese yen in an AHTML report, the Yen currency symbol is
not reflected in the excel spreadsheet generated using the Export to Excel option at runtime.
(191017136)
This release is now certified and has been tested with Google Chrome version 78, Firefox version 70, Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11.
