8206.14 Release Notes
Tuesday, January 21, 2020 | wf011520a Gen 141 | 8206 Gen 1755 |
as011520a |
- Conditional styling used with multi-drill (drillmenuitem) is not applied correctly in AHTML report output. (190903114, 191209162)
- A combination of a ReportCaster Schedule with a pre-processing focexec procedure that performs security processing in combination with Resource Analyzer results in an crashed agent. (190829102)
- MySQL® has been certified with the latest version of the JDBC driver (Connector/J). (191111022)
- Executing a procedure that contains Dialogue Manager commands after an ON TABLE PCHOLD command returns an internal error. (191104062)
- On a Windows® machine on which two servers with different releases are installed, when installing an additional configuration for the newer release, the install dialogue only displays the older release as the EDAHOME value. (190729132)
- When running Hyperstage on Windows, if the System Event Log is cleared while Hyperstage
is running and the bulk loader DLP is executed to perform a load of data, the Hyperstage
server becomes inoperable and unusable and any query shows file not found errors.
(191209028) - The combination of PRINT MAX.fields or another aggregating prefix with FORMAT SAME_DB
results in the skipping of the prefixed fields from the SQL generated. (191128006) - A report runs twice when executed from an HTML page. (191210013)
- Creating the default Business View for an OData synonym removes the REFERENCE= key
when the synonym is saved. (191016029) - When creating a DEFINE field that has a new line that starts with an asterisk (*), if that
character is added using the shift-8 key on the computer keyboard, rather than using the
asterisk (multiplication) from the keypad in the Define tool, the second line, beginning with
the asterisk, is removed if you save and reopen the procedure. (180427017)
This release is now certified and has been tested with Google Chrome version 78, Firefox version 70, Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11.
