8206.15 Release Notes
Friday, February 21, 2020 | wf021320a Gen 151 | 8206 Gen 1758 |
as021320a |
- HTML page layout with responsive template does not display properly when using the Google Chrome™ browser. (200110053)
- A second compute column displays incorrect numbers (plausible wrong results) when using the export to Excel® functionality with In-Document Analytics. (191021088)
- Date fields in chained hierarchies are not interacting properly with the other fields in the chain from the autoprompt screen. (190930096)
- Added enhanced flowing of compound reports across pages to ensure the correct pages are generated and page number information is available in more complex reports. (82552524, 11113001)
- If you subscribe to a Library item that is imported from another system, ReportCaster will use the value from the original system as the Library notification URL. (190520013)
- When in Manage Private Resources mode, a delete deferred report request fails against a cluster Reporting Server configuration. (190516014)
- Users with the privilege to CREATE SYNONYM (METAP) do not see a list of Adapter Connections and cannot create synonyms. (191106026, 191113095, 191015109, 191212164)
- The final SQL statement generates incorrectly by DataMigrator when using a filter with a specific combination of conditions. (200122015)
- An uploaded file used as a cross-reference in a Join to a host without any BV information only shows the cross-reference fields in the WebFOCUS field tree.
- Using the adapter for Salesforce.com® for a request with a child-to-parent join, a WHERE condition with an AND clause, or more than one WHERE or IF condition, and a field in the WHERE condition from both segments (data sources) will generate incorrect SOQL and the request fails. (200205086)
- Running an HTML report that contains OVER, ACROSS, and SET BYDISPLAY=ACROSS commands results in incorrect output. (190918031)
- Restore the \config\was\ folder during upgrades to preserve configurations files used by SAML authentication.
- Response time submitting a schedule manually has been improved. (190828112, 191126128)
- Redirection to the Client trace page (http://<host>:<port>/ibi_apps/WFClientTrace) occurs if there is a JavaScript error when a page reloads. (190815024)
- When creating a report in InfoAssist on a Business View that contains a Master File with a
global variable, the following error occurs: FOC295 VALUE MISSING FOR &&GLOBAL_VAR
(191114005) - A report fails when it contains the DB_INFILE function with a field from a folder and DBA in
the Master File. (191031065)
This release is now certified and has been tested with Google Chrome version 79, Firefox version 73, Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11.
