8206.16 Release Notes
Monday, March 9, 2020 | wf022820a Gen 157 | 8206 Gen 1761 |
as022820a |
- A flow contains corrupted syntax and is not scheduled when the Mail to addresses defined in procedure is used and the application directory name contains a percent sign. (191114059)
- Support added to the OData adapter to be able to filter on fields from child entity segments. (191202120)
- Deselecting a push button does not remove the filter on an HTML page or the dashboard. (191120073)
- Global Names set in App Studio are not updated across portal tabs. (191203023)
- In an SJIS or Unicode environment, an Excel® report does not download with .xlsx extension when viewed from an HTML page created by App studio that runs the referenced procedure (FEX) to create the Excel report and that procedure has a filter with a parameter using DBCS characters for a parameter name. (200124003, 200205001)
- The Parent-Response segment does not contain field definitions when a multi-segment JSON response is returned from the REST adapter Create Synonym process. (200114033)
- Using the irpcusf.js for translation, certain words from English to Portuguese are not showing in all the charts. (190924078)
- An error occurs when running WebFOCUS in Portuguese and creating a Reporting Object. (200125001)
- Salesforce® adapter query that uses BY TOTAL gets an error on a generated SOQL. (200210058)
- May 2020 has its last weekday on Friday the 29th and should be covered by the blackout
period, but the schedule can be saved without an error. (190510023)
This release is now certified and has been tested with Google Chrome version 80, Firefox Quantum version 73, Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11.
