8206.17 Release Notes
Monday, April 20, 2020 | wf041320a Gen 165 | 8206 Gen 1765 |
as041320a |
- On the Microsoft Windows® operating system, the Reporting Server’s TCP listener sporadically becomes unresponsive after a large number of connections. (190708017)
- Emails generated for Library subscriptions do not contain a subject line. (190508079)
- The WebFOCUS application receives various inputs from users, including values from HTTP headers and parameters to perform dynamic operations on the server side. If an exception is thrown, the application should catch it and return a generic error message that does not include any information regarding the system. (200211076)
- When using the adapter for Salesforce.com®, some server-generated SOQL (Salesforce Object Query Language) queries to retrieve data were not valid or efficient.
- An attempt to switch an adapter connection to a different user via SET CONNECTION_ATTRIBUTES/DEFAULT_CONNECTION commands or CONNECTION attribute in the Access File may fail if the adapter is JDBC-based and all connections have the same logical name. (200213038)
- Using the adapter forSalesforce.com® for a request using the NOT-FROM operator is converted to NOT BETWEEN a AND b in a SOQL request.
- A query using a prefix DT(YYYYMMDD) for a timestamp field generates an invalid SOQL request when using the Salesforce.com adapter.
- By default, Grant Password for OAuth security sends the Client ID and Client Secret as Base64 encoded for the authorization in the HTTP Header of the Token request. If BDYCLT:TRUE is added to the REST adapter connection string, the Client ID and Client Secret is sent as encoded parameters in the body of the token request. (200204125)
- When parsing an XML file, the parser does not disable the access to external entities, thus enabling payloads that might cause the server to perform unexpected actions. (200211064)
- Clicking on the Data tab from a Workbook results in an agent crash when the server is configured with the WebFOCUS Client REST adapter. (190628097, 190927075, 200214052)
- GEO ROLE is still generated when using Get Data after setting Activate GEOGRAPHIC_ROLE to Off and uploading a file. (190902027)
- Creating a savediag from the Web Console using a secondary administration ID (iadmin) and security provider OPSYS results in an error. Error: failed to run EXSDIAG Warning: can't find savediag log (190404027)
- Unable to create a savediag sometimes resulting in an EC6 abend where a REASON CODE=0594E04B is encountered. (200224015)
- App Studio closes unexpectedly when you right-click the Embedded CSS editor tab on the HTML canvas, uncheck Outlining and Auto Complete, and start typing any CSS code. (200128027)
- The WebFOCUS Administration Console displays Brazilian-Portuguese words incorrectly for
English words that contain special characters. (200408162) - NOPRINT fields are appearing in column menu tools of In-Document Analytics reports.
(191021095) - During WebFOCUS Client and WebFOCUS Integrated full or update Installation, the
repository utilities mask warnings and errors reported by the database and proceed as if
everything succeeded. (21353550) - Using IN-GROUPS-OF n TILES to group data in percentiles for reports or charts causes an
abend when used with SET EMPTYREPORT=ON and the request returns no
data. (200124059) - A WHERE clause using a field with the DBA property RESTRICT=NOPRINT is ignored,
allowing the field value to be printed. The WHERE generates an internal DEFINE that is not
associated with the original field. (200310047)
This release is now certified and has been tested with Google Chrome version 80, Firefox version 74, Microsoft Edge version 44 (WebFOCUS), and Internet Explorer version 11.
Java Version 8 or Java version 11 are supported with Release 8207. OpenJDK 8 JRE Update 242 (8u242) and Tomcat 8.5.51 are included with the packaging.
- Release: 8207
