8206.19 Release Notes
Friday, June 12, 2020 |
wf061120a Gen 194 wi061120a |
8206 Gen 1769 |
as061120a |
Adapter for REST: Setting a Default Field Length
The Adapter for REST SET FIELDLENGTH command sets a default USAGE and ACTUAL length for alphanumeric fields to be used when creating a synonym.
- Data entered into every other row of a grid gets shifted into blank rows when the form refreshes. (200601043)
- When accessing and opening a wide In-Document Analytics report as an email attachment from an iPad® with iOS version 13, you will get a blank space if you switch the orientation from Landscape to Portrait mode. (200403106)
- When more than 14 fonts are used in PDF format, they are not applied properly. (191230051)
- Data is not returned from a remote synonym that has a column with MDYY format. (200304045)
- Added the ability to set the default size for Create Synonym in the REST adapter. (200422088)
- Using the bulk load process to load Hyperstage data that contains missing or null values results in an error. (200311100)
- Resource Analyzer does not collect all the SMRPCNUM values for all procedures that are run. (191227007)
- When creating a coordinated compound document using a sort field that is defined as A87 or greater on a Unicode (UTF8) server, the agent crashes. (200317134)
- When saving an Excel® template to a folder path containing Kana Unicode characters and copying it to baseapp, the agent crashes when trying to use the template in a report. (190805011)
- The Datetime column in the ETL log is empty if a FOC2590 or FOC2594 error is returned for a procedure or flow. (200207056)
- When you select Popup style for a control and Add runtime Paging/Search Control at
runtime, the paging/search control will render all values despite the range set.
(200414007, 200414009, 200421020) - Running a Change Management import of a Portal twice results in an error: IBFSException 1244: ERROR_IBFS_INVALID_ARGUMENT_VALUE (200211001, 200226123, 200115003)
This release is now certified and has been tested with Google Chrome version 83, Firefox version 76, Microsoft Edge Chromium version 81 (WebFOCUS only), Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11 (Compatibility mode is not supported).
