8206.21 Release Notes
Thursday, August 27, 2020 |
wf082120a Gen 227 wi082120a |
8206 Gen 1772 |
as082120a |
- If an HTML5 (JSCHART) chart with a summary request that uses the chart’s bucket attribute syntax is run against an SSAS data source, the values on the x-axis correspond to the detail data rather than the summary data. (170616016, 200610117)
- A Synonym Editor in Data Management Console reports an error if a flat file contains a field without a FIELDNAME in a DUMMY segment. (200603038)
- An error occurs when trying to delete a Join in a two-page document in InfoAssist. (200706001)
- Unable to manually enter a date in the date picker in InfoAssist. (200609108)
- Warning message is not displayed when deleting a field from a Joined HOLD file that is referenced in an InfoAssist report. (200420065)
- When you right-click a dimension in the Data pane and select SUM, after changing it to COUNT or LIST, the field will still show MAX instead of listing or showing a count. (200123167)
- In Autoprompt, All values appears as Undefined in the selection dialog for optional static parameters. (200624063)
- In App Studio, legacy Portals created in 8.1.05M hang with script errors. (200729006)
- When using the Chrome™ browser, sometimes a form submission is not reaching WebFOCUS. (200618026, 200629105, 200710015, 200708129, 200611104, 200720062, 200714040)
- When a new folder is added to the multi-source tree control, subfolders are also created. However, in this case the folder does not have any subfolders designated. The control is generating numerous subfolders that were located in the other folders. The data or XML also does not indicate that the new folder has any subfolders. (200615057)
- A page is loaded before and after translations when the page contains Multilanguage. (200612007)
- When user select their language preference in BI Portal, calendar controls are showing up in the language selected which is great but it doesn't pull the data based on the selected month, It ignores the month selection. I am assuming it is because the name of the month not in English. (200325085)
- When using a responsive or non-responsive HTML file, the output of a chart changes. In the initial screen, the graph is displayed in full iframe. However, after opening the responsive HTML file, the chart is enlarged. (200424007)
This release is now certified and has been tested with Google Chrome version 84, Firefox version 79, Microsoft Edge Chromium version 83 (WebFOCUS only), Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11 (Compatibility mode is not supported).
