8206.22 Release Notes
Friday, September 11, 2020 |
wf090820a Gen 234 wi090820a |
8206 Gen 1773 |
as090820a |
- In App Studio, sort value is unselected when choosing ascending and descending values. (191101001)
- Wrong characters display in the labels of titles for Deferred reports when the Portuguese Brazil value is selected in the Enable Dynamic Language setting. (200818144)
- When running certain HTML pages in Internet Explorer® 11 that were originally created in an earlier version of App Studio (for example, 8.2.01), an error occurs. (200820013)
- If a grid contains a check box, and a user enters data containing a slash into another field, an error is displayed. (200730053)
- When the setStackedDataValueSum(false) property is designated in a JSCHART, the data labels output incorrect values. (200525010)
- Using ReportCaster to create a new schedule that distributes via email and selecting the Dynamic Distribution List from Repository Procedure option causes an error. (200206075)
- When embedding custom font "Raleway" into a PDF output and using WRAP in InfoAssist, text is not displayed correctly. (200709142)
This release is certified and has been tested with Google Chrome version 84, Firefox version 79, Microsoft Edge Chromium version 83 (WebFOCUS only), Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11 (Compatibility mode is not supported).
