8206.23 Release Notes
Friday, October 9, 2020 |
wf100520a Gen 240 wi100520a |
8206 Gen 1775 |
as100520a |
- Invalid JSON is sent in the body of the POST request based on an authentication Master defined by chained authentication. (200602034)
- When creating bar charts in InfoAssist using the New option on the ellipsis menu, the Color bucket incorrectly performs a count for a dimension field. It also shows a heat legend. (200722018)
- When creating a condition in Tasks & Animation, an error occurs when there is a selection change. (200508085)
- When selecting certain options on an App Studio HTML page with an event to hide a PDF image and radio button, the image number keeps changing and the image does not always hide. (200727033)
- When you select Popup style for a control and Add runtime Paging/Search Control at run time, the paging/search control will render all values despite the range set. (200421020, 200414009, 200414007)
This release is certified and has been tested with Google Chrome version 85, Firefox version 80, Microsoft Edge Chromium version 85 (WebFOCUS only), Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11 (Compatibility mode is not supported).
