8206.25 Release Notes
Friday, December 4, 2020 |
wf113020b Gen 251 |
8206 Gen 1777 |
as113020b |
- Fixed: Connections in Group Profiles are not available in the Get Data section. (200819155, 200909143)
- Fixed: An Excel sheet exported from an Analytic Document is corrupted. This issue occurs with the following three conditions: COMPUTE or DEFINE field in Px.x% format, BY field, ACROSS field. (200617010)
- Fixed: After selecting clear buckets content in an active chart, the user is unable to add fields to the query. Issue only pertains to ARVERSION 2. (200806017)
- Fixed: Db2 CreSyn gets empty list of candidates if schema has trailing blanks and wildcard is not used.
This release is certified and has been tested with Google Chrome version 86, Firefox version 81, Microsoft Edge Chromium version 85 (WebFOCUS only), Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11 (Compatibility mode is not supported).
