8206.26 Release Notes
Wednesday, January 13, 2021 |
wf010821a Gen 263 wi010821a |
8206 Gen 1778 |
as010821a |
- Fixed: Performance issue with Designer when the Master File List is being displayed. (201116042)
- Fixed: Publishing and unpublishing multiple ReportCaster schedules from ReportCaster Explorer does not work. (200820005)
- Fixed: Unable to select a Saved Parameter if there is only one saved value in App Studio. (201203011)
- Fixed: App Studio crashes when creating and editing an HTML Mobile Design with Responsive Design. (210106011)
This release is certified and has been tested with Google Chrome version 87, Firefox version 83, Microsoft Edge Chromium version 86 (WebFOCUS only), Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11 (Compatibility mode is not supported).
