8206.28 Release Notes
Thursday, March 4, 2021 |
wf020421a Gen 273 wi020421a |
8206 Gen 1781 |
as020421a |
- When scrolling through pages, the table display is corrupted. This issue only occurs in Legacy In-Document Analytics in Chrome, Firefox, and Edge browsers. (201216005)
- When building a dashboard containing a report and using an Alphanumeric format field as a coordinated field to screen on number values, the output is blank. (200415073)
- App Studio crashes if you try to change the title from the Multi-Language properties dialog box. (210211070)
- When a drill down on a report is clicked, the multi-drill menu pops up or renders near the top of the html page. (191219076, 210120013)
- A DEFINE with a MISSING value designated generates a "_FOC_MISSING" into a drilldown parameter. (201125011)
- Issue with Salesforce® adapter after upgrade installation. (201221017)
- WebFOCUS Report and Portal performance is degraded when enabling Resource Analyzer. (200305128, 200821088, 200706024, 201220001, 201210028, 210108014)
This release is certified and has been tested with Google Chrome version 88, Firefox version 85, Microsoft Edge Chromium version 87 (WebFOCUS only), Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11 (Compatibility mode is not supported).
