8206.29 Release Notes
- When launching an active report, the “Loading” screen does not display for the full loading process. (200507088)
- When a report uses a parameter that contains a very long string (for example, 400+ characters total), and the format is AHTML, an agent crash will occur. (210303029, 210308007)
- Timestamp is not showing in the event.log file after changes to log4j2.xml. (210202025)
- In App Studio, sample data is not available when creating a chart if the “All User Override” checkbox is not selected. (201118043)
- ReportCaster Stopit.sh script returns many variables to the screen once executed. (190319057, 210330079)
- Integers do not display as expected. (200721046, 210303020)
- The drilldown on ACROSS COLUMNS fields on a VARCHAR field will cut off the first 2 characters, therefore no match in the target fex. (210106015)
- UTF-8 and SET BOM_OUTPUT = ON causes FOC1522 error with XLSX format. (210124003)
- When running a TABLE FILE request to a Vertica master, an error appears if the customer uses SEG.fieldname and ON TABLE SAMEDB
- Title line of the csv file output in format COMT is missing the trailing double quote when the total length of the title is more than 4096 bytes. (201225005, 210310017)
- Trusted connection to a Reporting Server allows a fex to execute even if the password is invalid or expired. (191212108)
- APP MAP applications in user profiles are not cleared properly. (201210063)
This release is certified and has been tested with Google Chrome version 90, Firefox version 88, Microsoft Edge Chromium version 89 (WebFOCUS only), and Microsoft Edge version 44 (WebFOCUS only).
Effective April 1, 2021, all new releases of TIBCO WebFOCUS® following Release 8207.27.0 will no longer support Internet Explorer 11 as a certified browser. For the full statement, see here.
