8206.33 Release Notes
- CVE-2021-44228 and CVE-2021-45046, remote code execution vulnerabilities in Apache Log4j. (To obtain the hotfix for 8206.33 which resolves these vulnerabilities, please open a case with TIBCO Support.)
- On Restore, Drilldown Constant parameter in chart changed to Field from 8207.29 to 8206M.
- AppStudio 8206.33 upgrade installation throws a "Failed to backup AppStudio installation" error message. (2067039)
- WebFOCUS 8206.33 installation generates the "Failed to start windows service:Derby" error message when installed on a TIBCO machine. (02034098, 02029713)
- After installing HotFix 10, reports with "define" fields cannot be opened without redefining the fields. (02034094)
- Security tab fails to display and generates an Uncaught Type error when selected from the Administration Console page.
This release is certified and has been tested with Google Chrome version 94, Firefox version 92, Microsoft Edge Chromium version 89 (WebFOCUS only).
Effective April 1, 2021, all new releases of TIBCO WebFOCUS® following Release 8207.27.0 will no longer support Internet Explorer 11 as a certified browser. For the full statement, see here.
