8206.20 Release Notes
Thursday, July 16, 2020 |
wf071020a Gen 208 wi071020a |
8206 Gen 1771 |
as071020a |
Adapter for REST: Sending Credentials in the POST Request Body
When OAuth authentication is used for the Adapter for REST, and the OAuth Grant Type is Password, the configuration parameter Client Credentials in Body has been added to the connection configuration panel, as shown in the following image.
Selecting this option will add the attribute bdyclt:true in the connection string.
By default, client credentials for OAuth Grant Type Password are sent Base64 encoded in the HTTP header. However, if the web service being used does not support sending these credentials in the HTTP header, you can use this feature to send them in the body instead.
- Radio buttons typically do not use the ID attribute of the object and use the name instead, however, if custom JavaScript makes use of the ID, it will not work. (200612010)
- When an HTML Canvas page loads, the window_onload() function is called after the UpdateData() call and now requires the use of onInitialUpdate(). (200612011)
- A page is loaded before and after translations when the page contains Multilanguage. (200612007)
- The client ID and secret are not sent in the token request body during Create Synonym when BDYCLT:TRUE is configured in the REST Connection.
- When using App Studio in French, some of the Properties of the HTML canvas are not properly translated. (200608040)
- When an ARVERSION=2 request returns a large recordset, it is taking an excessive amount of time to display the content.
- When an Advanced User is denied the Data Visualization from Metadata privilege, the EDIT option is missing for a newly created focexec.
- An issue occurs causing an Agent Crash when interpreting the XML response from a REST request using the REST adapter when the XML response contains only two tags.
- A double list box control does not pass multiple selected values to a report. Only the first value is displayed.(200624003)
- When running an HTML page, the quotation marks around the parameters are missing. (20061500, 20061501, 200713082)
- When adding two specific lines of code to an IDA report, the report runs with errors. (191112041)
- A multiple-select list box does not populate an existing single parameter with "OR". (200611030)
- When using a combination of bullets and numbering options, a </lispan> tag renders in the PDF. (200608011)
- A field with define is replaced in Live Preview when you reopen the editor in InfoAssist. (190702005)
- When sorting on a compute field in a define in a visualization, an agent crash occurs. (200319053)
- Missing translations in radio buttons in App Studio. (200612010)
- When sorting and filtering data at run-time in an AHTML report that HFREEZE, the columns titles are misaligned when there are many columns in the report. (200402081)
This release is now certified and has been tested with Google Chrome version 83, Firefox version 77, Microsoft Edge Chromium version 82 (WebFOCUS only), Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11 (Compatibility mode is not supported).
