8206.04 Release Notes
Friday, August 16, 2019 | wf081319a Gen 62 | 8206 Gen 1742 |
as081319a |
New WebFOCUS Integrated Installation
WebFOCUS Integrated Installation is a new, simplified installation, which installs and configures all required product components to allow you to use the product for your reporting and analytics needs.
WebFOCUS Integrated Installation is an all-in-one downloadable installation package. Benefits include:
- WebFOCUS and the Reporting Server bundled with Tomcat, Derby, and Java.
- Hyperstage preconfigured as a high-speed target for uploaded data.
- Simplified configuration for email distribution.
With WebFOCUS Integrated Installation, you can quickly and easily perform reporting and analysis, data discovery, and scheduling and distribution, all in a single web-based environment.
For more information, see WebFOCUS Integrated Installation.
New Integration of the Solr Search Platform With WebFOCUS
You can now configure Solr, an open-source, high-performance, full-featured enterprise-search platform, to work with WebFOCUS features. Solr uses the Apache Lucene Java search library as its core for searching and indexing. The WebFOCUS Integrated Installation and WebFOCUS Client create a directory with zip files that contain Solr indexes for the retail samples data and the Solr Version 8.0.0 distribution archive, which enable Enterprise search and analytics.
The following Information Builders features make use of the Solr platform:
- InfoSearch
- WebFOCUS Home Page
- Home Widget
- Navigation Widget
WebFOCUS Repository Procedures Are Now Available for Use as Pre- and Post-Distribution Schedule Procedures
The Task Pre/Post Processing Procedures dialog box now includes links to procedures located in the WebFOCUS Repository, as well as the Reporting Server, as shown in the following image.
This new capability expands the range of pre-processing and post-processing procedures you can attach to distribution schedules to include procedures located in the WebFOCUS Repository as well as those located on the Reporting Server.
For more information, see the Schedule Pre-Processing and Post-Processing Procedures topic in the ReportCaster Guide.
Adapter for REST: Enabling Support for Custom Headers
When you configure a connection for the Adapter for REST, you can now add custom headers consisting of name=value pairs that are passed in the HTTP headers.
To add custom headers for a REST connection, on the Connect to Data page of the Web Console, either add REST to the configuration or, if the adapter is already configured, edit an existing connection or add a new connection. In the Advanced HTTP connection options section, click Add Custom Headers.
A text box opens in which you can add the custom header, as shown in the following image.
Custom Header values should be enclosed in double quotation marks, and the individual custom headers should be delimited by semi-colons (;). For example:
Content-Type="CDF";PARAM1="ABC"
Custom headers can also be created in the metadata as part of the process of creating a synonym. Defining custom headers in the connection string makes the custom headers apply to the entire REST service. Defining the custom headers at the metadata level makes the custom headers apply to the specific REST call, and the custom header values can be changed at report time using WHERE or IF statements.
For more information, see Adapter Administration.
Automatically Adjusting Only the Width of a Chart
This feature enables you to adjust only the width of a chart without adjusting the height, giving you more flexibility in displaying chart output. When the AUTOFIT parameter is set to ON, chart height and width are adjusted to fit the size of the container. When the AUTOFIT parameter is set to WIDTH, the width of the chart is adjusted to fit the width of the container without adjusting the height.
For more information, see Creating HTML5 Charts With WebFOCUS Language.
- When creating a chart from App Studio, the Run with OLAP property is enabled when it should not be. (190730106, 190722101, 190729102)
- Unable to control borders within internal cells in a heading and footing in XLSX or HTML reports. (20553557, 70352006, 80172024, 90592515, 92672521, 11813555, 30393512, 161012021, 170125094, 170223043, 170428050, 170517097, 170621009, 30063540, 160329026, 22093513, 180522092, 190320059)
- A report containing many spot markers for fields is triggering an agent crash error. This occurs with all styling formats. (190529056)
- An XLSX report may not open when a numeric field used in a styled multi-item heading is either zero, formatted with the S option, or missing with the NODATA set to a blank value. (190108003)
- User receives unreadable content errors while running an XLSX template report and trying to open the report in Excel 2010 or Excel 2013. (190725070)
- When a field containing ACCEPT= code is dragged or dropped onto the Business View pane, the ACCEPT code is executed causing a potential performance issue with re-drawing the Business View structure. (190328032)
- If a username contains a period, and therefore their My Content folder contains a period, saving a focexec procedure from Designer to that user's My Content folder, corrupts the focexec procedure. (190401081)
- The enhanced In-Document Analytics user interface available is configured by default for new installations and is not supported with the Microsoft Internet Explorer 11 browser. If you have requirements to support Microsoft Internet Explorer 11 browser, you can configure the Legacy In-Document Analytics user interface using the WebFOCUS Administration Console.
- When clicking a column for a report that has only the Freeze option enabled, and the width of the report container is big enough to display all columns, a blank column menu displays.
- When working in Document mode with In-Document Analytics, an error occurs if you attempt to run a document or dashboard using Internet Explorer 11.
- When creating reports in WebFOCUS Designer using the Technical Preview feature, the default font may not display all NLS characters correctly. To ensure that these characters display properly in reports, change the values of the FONT attributes, in the report section of the embedded StyleSheet you are using, to a font that supports the required NLS characters. For example:
- When using the Chrome 76 browser, the show filter panel icon on the responsive autoprompt interface does not redisplay the filter panel after the first run of a report with parameters. This behavior does not occur with the Chrome 77, Firefox, or IE11 browsers.
This release is now certified and has been tested with Google Chrome version 76, Firefox version 68, Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11.
