8206.08 Release Notes
Friday, October 11, 2019 | wf100819a Gen 99 | 8206 Gen 1746 |
as100819a |
HTML5 Chart Types Now Support Bursting and Scheduling
HTML5 charts can be burst and scheduled for distribution by ReportCaster. Chart requests that use chart attribute syntax are burst on a field assigned to the page attribute category. Chart requests that use legacy syntax must be multi-graph requests in order to be burst.
- A DBCS character entered in the Custom Settings configuration option in the Administration Console does not display the DBCS character. (190627007)
- The Loading screen image remains after the HTML composer page is loaded. (190808104)
- App Studio crashes when trying to drag and drop components of a report in Procedure View. (190724020)
- The jQuery animation is not working correctly after migration. (190807086)
- Switching tabs in an HTML page displays an error within the browser. (190918087,190923095)
- App Studio crashes when opening specific, large HTML pages. (190923023)
- Unable to display an image as a DEFINE field when using WRAP and PPTX as the output format. Also, for all styling formats (PDF, EXL07, DHTML, PPTX), specified column widths are not respected if images are present in data columns. (170921006)
- App Studio crashes when opening specific HTML pages. (190923023, 190924128,
191008076) - When the Reporting Server is configured with Data at Rest encryption, agent trace and
agent output are encrypted preventing the trace and output from being viewed from the
regular editor. Trace and output can only be viewed from the Web Console by Server
Administrators. (190818003) - The user receives Permission Denied error while running an HTML5 chart. (190621077)
- Users in groups are able to see group profile adapter connections they should be restricted
from. - Japanese characters are garbled after importing a Change Management package.
- When clicking a column for a report that has only the Freeze option enabled, and the width of the report container is big enough to display all columns, a blank column menu displays.
This release is now certified and has been tested with Google Chrome version 77, Firefox version 69, Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11.
