8206.11 Release Notes
Friday, November 22, 2019 | wf111919a Gen 121 | 8206 Gen 1751 |
as111919a |
- Unable to delete a JOIN in a multi-fact Master File in a Metadata canvas. (191018008)
- Creating a synonym for the REST adapter with Resource Management active may result in the following error: FOC1544 Syntax error (191105068)
- JSON Array notation was not being set when ACCESS_PROPERTY=(ARRAY_ITEM) was set in the Metadata and proper statements were sent in the request. (191028106)
- An invalid URL was created with multiple question mark characters (?) while signing out of a WebFOCUS portal when WebFOCUS was configured for Security Assertion Markup Language authentication and single sign out was disabled. (191003101)
- Web Console support was added for the OData Aggregation Extension setting. (191112059)
- The jakarta-regexp-1.5.jar file has been removed.
- If an iframe is being loaded with another HTML Canvas page, there will be a spinner for the loading of the page, and then another spinner for the content on that page. (191011031)
- The checkbox control fails when using IBComposer_setCurrentSelection with multiple values. (191021066)
- The text on push-type radio buttons disappears with hide or show animations. (191101025)
- Dynamic Symbol Settings does not refresh the Image Source, Color or Image Angle. (191007019)
- ONLOAD will not select the correct value if there are over 100 values in a control that it is chained to. (191108001)
- Setting security to shared results in a NullPointerException error when the schedule is
executed. (190822154) - JSON array notation is not set when ACCESS_PROPERTY=(ARRAY_ITEM) is set in the Metadata and proper statements are sent in the request. (191028106)
This release is now certified and has been tested with Google Chrome version 78, Firefox version 70, Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11.
