8206.12 Release Notes
Friday, December 6, 2019 | wf120319a Gen 126 | 8206 Gen 1752 |
as120319a |
- When setting a SUM field to Japanese yen in an AHTML report, the yen currency symbol is not reflected in the Excel® spreadsheet generated using the Export to Excel option at run time. (191017136)
- Running a procedure with an Excel template results in an error. (190723124)
- When running an HTML report with PRINT and GRANDTOTAL, the font size of the grand total does not match the rest of the report, even though the font size was not set for the grand total. (190826009)
- If the value of a field in an HTML drill-down report starts with a period, WebFOCUS passes the value as _FOC_MISSING. (191017017, 191018023)
- Running a procedure that has an Excel template results in an error preventing the population of the macros and buttons in Excel. (191023030)
- Attempts to add a new chart fail with an http503 error in Designer when authentication to WebFOCUS Server is configured for Kerberos. (190905049)
- Savediag on the Web Console fails when running from a secondary (non-installation) iadmin ID and security provider OPSYS. (190404027)
- When building a request in WebFOCUS that references a permanent DEFINE in a Business View synonym, the fully qualified name (synonymname.segmentname.fieldname) in the request may result in an error. (190723037)
- The items in a list box control in an Excel template overlap after feeding it data from a WebFOCUS XLSX report. If any items are selected, the date on the first sheet's Balance Sheet does not update. (190816039)
- A request that contains a fully qualified DEFINE field resulted in an error: FOC003 THE FIELDNAME IS NOT RECOGNIZED: SEGMENT.FIELDNAME (190723037)
- Specifying cell padding in the Matrix view causes Report canvas to crash. (191002069)
- The text area value is not saved correctly on the second Save selection. (190325026)
- Settings dialog tab does not show the selected radio buttons for Sort by and Sort order.
(191101001) - The TAB key does not advance to a radio button set as a push button. (191108032)
- Maintain migration does not create valid syntax when Winform Set commands are used on
the right side of an IF THEN ELSE statement. (191111030) - The Winform set Form.field.Enabled to var code is assigned to Disabled property of the
object which disables the field. (191113124) - A request that contains a fully qualified DEFINE field resulted in an error: FOC003 THE
FIELDNAME IS NOT RECOGNIZED: SEGMENT.FIELDNAME (190723037) - Running a dashboard that submits multiple requests against a Vertica database can result
in a JSCOM3 crash due to the number of concurrent requests to the Vertica JDBC driver or
JVM. (191004040)
This release is now certified and has been tested with Google Chrome version 78, Firefox version 70, Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11.
