8206.18 Release Notes
Tuesday, May 19, 2020 | wf050720a Gen 175 | 8206 Gen 1767 |
as050720a |
Adapter for OData: Support for Selection on Aggregation
If you configured your OData connection with the Aggregation Extension, as shown in the following image, certain OData requests that involve summation or summation prefixes will send OData requests based on the OData Aggregation Extension specification.
This feature adds filters to the syntax of an OData Aggregation Extension request when WHERE_GROUPED or WHERE TOTAL is used in a WebFOCUS report.
Track Time for XML Adapters
On the Server Workspace page, a table of data service agent statistics is displayed for use in monitoring server performance, as shown in the following image.
The column DBMS Time is used to track the amount of DBMS processing time in seconds that is used to retrieve the data when a request is run.
- When a connection to a remote server is deleted from one user profile, it gets deleted from all user profiles. (200117051)
- When using the advanced mode to upload an Excel® workbook with a name that includes periods and contains multiple worksheets, dragging a worksheet to the Join editor results in an error. (200128075)
- Encode Filter parameter values in OData Adapter Aggregation requests. (200317064)
- The displayed output for sorting a field in descending order is not sorted correctly in an aggregated OData request.(200311015)
- An attempt to switch the adapter connection to a different user (via SET CONNECTION_ATTRIBUTES/DEFAULT_CONNECTION commands or via the CONNECTION attribute in the Access File) may fail if the adapter is JDBC-based (e.g., Vertica®) and all connections have the same logical name. (200213038)
- HOLD APPEND for Bulkload does not always load the records to the Target. (191203041)
- Agent crashes when a report is run multiple times in PostScript® format, with the Lucida Sans Unicode font. (190403174)
- When accessing and opening a wide In-Document Analytics report as an email attachment from an iPad® with iOS version 13, you will get a blank space if you switch the orientation from Landscape to Portrait mode. (200403106)
- Garbled characters are generated in a focexec when pasted to the desktop outside of
AppStudio. (200331072) - Including a repository focexec procedure using the legacy relative folder reference
(INCLUDE ./subfolder/xxxx.fex) fails when the main focexec procedure is run. (200429027) - The POSITION and TOKEN functions generates incorrect SQL resulting in errors from Db2.
(200228064)
This release is now certified and has been tested with Google Chrome version 81, Firefox version 75, Microsoft Edge Chromium version 81 (WebFOCUS only), Microsoft Edge version 44 (WebFOCUS only), and Internet Explorer version 11 (Compatibility mode is not supported).
